CDL Air Shifter
Old Mar 23, 2011 | 06:59 AM
texmbr's Avatar
Default CDL Air Shifter
Has anyone tried one of the CM Air Shifter's? Found this while looking for shifter optionas as I'm about to convert my non-cdl to cdl and don't really want a D1 shifter and the price of the 04 is steep and hard to find. Anyone?
CM Manufacturing - Air Shifter CDL (Center Differential Locker)
Old Mar 23, 2011 | 07:17 AM
hilltoppersx's Avatar
do what i did. screwed the nut over the cdl. JB welded ($4) a 13mm deep well socket ($3) and a harbor frieght wobble extension ($7) on top cut a hole in the console and it sits flush under the rubber mat. just click it in and out when i need it. total cost whopping $14. or you can be crazy and buy some air powered $400 solenoid. personally im broke so i went the most simple way possible.
Old Mar 23, 2011 | 07:26 AM
texmbr's Avatar
Have seen a couple similar designs..not bad. Was just curious as I can copy that design for a whole lot less meaning the CM. Really not much to it. I was just curious about the dependability of one of these gizmo's. Plus I have the new transfer case sitting on the bench so I look at it alot thinking "I should be able to design something and not spend 350 bucks". It's just a lever.
Old Mar 23, 2011 | 07:34 AM
drowssap's Avatar
texmbr,
there are a couple of videos on utube of this shifter in action, accually its a motorcycle air shifter converted. I liked it, the only thing I was not sure of is if the CDL lever or the shifter is spring loaded to return. If it is; you would have to have air to the shifter the whole time it is locked. If not you only need air for a split secound, I was think I could probablly get away with the air compressor from my SLS system in that case.
Old Mar 23, 2011 | 07:41 AM
texmbr's Avatar
I did watch those and no doubt very similar to the air shifter on my son's GSXR. Looks to be a single action so constant pressure would be reuired untill selonoid release. Great idea on the SLS compressor. They make the exact same cylinder unit in a dual action also. Momentary air pushes the cylinder in each direction..not spring loaded.
Old Mar 23, 2011 | 10:55 AM
Snafu / Disco Fries's Avatar
I'll provide the beer and parts if you provide the expertise Also, do you have pics of it inside the truck?
Old Mar 23, 2011 | 12:09 PM
ill take pics and post it. don't have any handy.
Old Mar 23, 2011 | 03:43 PM
TY sir. I keep thinking that is the direction I want go.
Old Mar 23, 2011 | 03:54 PM
i think it is the direction everyone should go.
Old Mar 23, 2011 | 04:01 PM
texmbr's Avatar
Anything like this?
http://www.discoweb.org/cdl/index.htm
