CDL detection switch
I got a new CDL switch yesterday from AB. When I was installing it, I tightened the bolt until it was flush with the t-case and then tightened it just a bit. One of the little prongs came off, so I had to take it out and I was going to solder the two prongs right on there so they wouldn't come off. (it seems like they only use like super glue to attach them)
Anyway, when I pulled the switch out, the bottom was deformed. Where the spring loaded **** pokes out, that bolt part looked like it had been ovaled and the **** that is supposed to poke out was jammed up inside the bolt. Can this be caused by tightening it down too much? It looks like it was forced into something and that's what curved the bolt. When I removed the original, there was no such problem or deformation. Any ideas?
Ah. You are right. I remember now. The original had a nut on it, but the new one did NOT come with the nut. I ordered a new one yesterday. This time I will remember to put that nut on there.
Well hopefully the second go around will work better than my first attempt
but I really love driving around with my entire console completely apart and having the freezing cold air blowing up through the big hole in the middle.
Thanks Jafir. I feel a little silly I didn't catch that.
but I really love driving around with my entire console completely apart and having the freezing cold air blowing up through the big hole in the middle.Thanks Jafir. I feel a little silly I didn't catch that.
That sounds nasty. I will say though, it's been snowing here, and every now and then, I get a nice wet splash of cold water on my arm or cheek. Not very fun either... and my wife won't ride in it so we have to take her car everywhere
So why couldn't you soulder the prongs to the little post coming up? It seems like this would give you a much more solid connection
Never said you couldn't. Solder would have probably been the better route to take. The switch will never see enough V/A to cause me problems. Further, the circuit is open more than it's closed. If it fails, I'll replace it.
