CDL detection switch
Old Feb 19, 2013 | 08:01 PM
jafir's Avatar
Originally Posted by jfall
Does my Discovery 2001 still have a CDL switch?
I know I can't go to CDL as that mech is missing.
But, if I put it into CDL manually, is that switch and the CDL light still on my dash?
If you don't have the CDL bits inside the case, it won't have the switch. If you do have the bits, but don't have the shifter, the switch should be there.
The lights will still be in the cluster.
Some of the non-cdl cars have a harness that can be plugged into the switch, if you decide to swap your case. Some do not, and you have to splice into the harness.
Old Feb 20, 2013 | 04:24 AM
NickAdams's Avatar
Default Does my Discovery 2001 still have a CDL switch?
My 2001 does. 05/01 build. Kinda sexy to see the indicator light on when locked in!
Old Feb 22, 2013 | 08:31 PM
bballjames's Avatar
Just wanted to give an update. Got the new switch in today, and that was the problem. I guess my original had failed. Now the CDL and light engage properly. Boy those little electrical terminals are fragile. I broke the first and had to order another. Glad to have it fixed. I also got a much better seal with some RTV silicon now on the shifter plate. It's nice and quiet now.
Old Feb 22, 2013 | 08:49 PM
CANAMDiscovery's Avatar
Yes I would say so... I manually set mine (while front driveshaft was off) Here is the light on the dash... Does not come on until you engage the transmission.
turbodave
Mar 29, 2019 07:22 AM
Dweller in the Desert
Aug 19, 2015 06:21 PM
0304Disco
Oct 22, 2012 09:43 AM
cobbcj7
Jan 3, 2012 07:47 AM
mr_boondoggle
Jan 19, 2009 02:15 PM
