CDL Help
Old Mar 25, 2013 | 02:17 PM
MONEYMIKE's Avatar
Default CDL Help
I took apart my center console yesterday, so I can check if i had CDL. by the looks of the connection with the center bolt in the my images I posted, it looks like a CDL connection, right? but when I look at lever on the left side.... theres a metal piece that looks like it blocks the lever to move the left .... so wanted to know if thats supposed to be there... also wanted to know if this is a actual cdl linkage....im new!!
Attached Thumbnails CDL Help-image-2-.jpg   CDL Help-image-3-.jpg   CDL Help-image.jpg
Old Mar 25, 2013 | 02:29 PM
ZGPhoto's Avatar
Yeah that's a CDL lever. Not sure about the blocking metal piece.
Old Mar 25, 2013 | 02:33 PM
cosmiccharlie's Avatar
Yes you have CDL. And from the looks of it an 04 Disco, unless someone added the cable linkage to a 99-01. Does your console not have a label and **** that looks like this? What year is your truck?
Old Mar 25, 2013 | 02:52 PM
MONEYMIKE's Avatar
Well reason I took this apart is because it wasnt moving to left and was thinking theres was no cdl connection ... But if it is a cdl libkage that means it was rust not making it move right? And yes i have that diff lock label sticker and on the ****... I have an 04 discovery
Old Mar 25, 2013 | 03:12 PM
ZGPhoto's Avatar
All 04s should have it.
Old Mar 25, 2013 | 03:24 PM
MONEYMIKE's Avatar
Question.... Can i move the cdl without mounting it ...so I dont have to re-rivet everything
Old Mar 25, 2013 | 03:59 PM
Everything looks fine, maybe lube everything up well and try to move the shifter. It doesn't move very far to the left before the CDL engages.
Old Mar 25, 2013 | 04:35 PM
MONEYMIKE's Avatar
Ok putting PB blaster on and hope it works
Alright then.... So theres nothing that looks out of the ordinary? Its certain its a cdl
Old Mar 25, 2013 | 06:01 PM
Does the shifter move at all? Can you shift to Low? Nothing looks out of the ordinary. Yes, certain it is has a lockable center diff with the factory CDL linkage. Here is a comparison of how the shifter looks in High/Unlocked vs. High/Locked. It doesn't have to move much.
High/Unlocked
High/Locked
And this should illuminate on the dash when locked.
Old Mar 25, 2013 | 06:11 PM
Jared9220's Avatar
This might be a stupid question but are you putting the car in Neutral Before you try move the CDL?
This might help give you an idea of what you are looking at:
