cdl question
Old Aug 29, 2012 | 05:11 PM
lr2001silver's Avatar
Banned
Question cdl question
Is the 04 CDL set-up a direct fit for a 01?
Old Aug 29, 2012 | 06:03 PM
bigcraigman's Avatar
I am lucky and just need the linkage in my 2001 but just don't want to spend the 500 on the linkage. I need to find a junkyard with a disco. I know a d1 linkage works but with a little tweaking. I read on one post which I can't find anymore that some used an aircraft control arm to rig something up. Not to mention the project takes a bit of time. Do you just need the linkage too or the internals?
Old Aug 29, 2012 | 06:21 PM
Banned
You need the linkage and shifter and can make a d I set up work without the little air craft part. You cant just ad the linkage to your factory D II shifter. Everything depends on what month in 2001 your truck was built some have the internal gears and some don't. If you want to buy a D I shifter you can pm me but none of that was related to my original question.
Old Aug 29, 2012 | 07:17 PM
Banned
Anybody?
Old Aug 29, 2012 | 08:58 PM
ralphobell's Avatar
Are you asking if you can take the CDL linkage from an 04 and place it on an 01? I believe you can. I used one from a 98 D1 and used the control arm method.
Here is what he was talking about the control arm. It does not have to be for aircraft. Just happens the one that was used in the original was. I'm the one that posted finding the control arm on Amazon etc. To me it is a cleaner and easier way to go then bending the arm.
Discovery 1 CDL into Discovery 2 - Land Rover Forums : Land Rover and Range Rover Forum
Old Aug 29, 2012 | 09:06 PM
Yes, if you want the 04 cable set up you can do it.
Old Aug 29, 2012 | 09:08 PM
Banned
Yes that's my question i have put in a few with the D I setup. But did not want to cut the whole and all the stuff to put in the D I in this truck. I was looking to see if the 04 setup is a direct fit meaning i eould have no cutting or blacksmithing lol i am just wandering if the 04 fits just like the Ashcroft cable setup?
Old Aug 29, 2012 | 09:09 PM
Banned
Thanks mike i was waiting for your answer! Is it the same as Ashcroft???
Old Aug 29, 2012 | 09:13 PM
Pretty sure it is the same.
Old Aug 29, 2012 | 09:15 PM
Banned
Thanks alot i will try it!
