cdl question
Old Aug 29, 2012 | 10:09 PM
FLDiscoII's Avatar
I may be off base on this, but I'm pretty sure that even with a '04 shifter you'll still have to cut the hole in the cover. You still need to make room for the lateral shifting.
Old Aug 29, 2012 | 10:44 PM
bigcraigman's Avatar
Thanks for the post Ralph. I had forgotten where I had seen it.
Old Aug 29, 2012 | 11:25 PM
lr2001silver's Avatar
Banned
Okay i thank everyone for the inputs i understand that either way i go the 04 is way more expensive but is all cable operated vs the mechanical rod set up of the D 1. Also either way i will be doing a little trimming for the side to side movement. I have placed the order for the 04 setup and will hopefully get that installed this weekend!!!
Old Aug 30, 2012 | 06:53 AM
drowssap's Avatar
Also going with a cable type shifter will eliminate all the vibration that is associated with using the D1 shifter
Old Aug 30, 2012 | 08:25 AM
Banned
Sweet i cant friggin wait. I knew it was a better way to go ! just harder to find and ouch on the billfold.
Old Aug 30, 2012 | 08:34 AM
drowssap's Avatar
there was a guy on ebay from POLAND that was selling them for $269.00 when i bought mine, I think they were 299.00 last i looked
Old Aug 30, 2012 | 08:40 AM
Banned
Thanks guys
Old Aug 30, 2012 | 10:45 AM
909wheeler's Avatar
£240.00 or $380 USD.
CDL Land Rover Discovery 2 D2 diff-lock shifter difflock | eBay
Cheaper to source one locally at a salvage yard.
Old Aug 30, 2012 | 11:35 AM
drowssap's Avatar
same shifter & cable different seller he must be buying them from the same guy i did and reselling them.
Old Aug 30, 2012 | 12:29 PM
Banned
I got mine for less than half that!!! Comes with all clips, nuts, bolts and a new shift boot and handle.
