CEL after I did the Seafoam through the Vaccuum line!!!
Like Sloppy says; no worries. It is considered a "soft code" and will reset after a few start cycles. Last time mine reset after very few miles. I was doing some shopping at different stores and when I started her after my last stop, it had turned off. I did not count the start cycles, but it was probably only about 5. I will be doing mine tonight again, and will keep a close look at the quantity of start cycles it takes to go out again and report back for future reference.
Cheers!
Cheers!
It already went off. About 5 cycles and maybe 30 miles after. I was worried. Boy! You guys wern't kidding when you said it would smoke like bejesus in the other threads! The cars behind me were slowing down! HAHA! Killed every skeeter this side of the Mississippi! I Have the oil draining overnight and I'll finish up the oil change in the morning(Penzoil Platinum 10w30 with a Mobil1 oil filter). Then I'll be installing a new set of Bosch Platinum+2 spark plugs. After I finish up the tune up I'll report back with any improvments. I did a can through the vaccuum line and a can in the tank.
I can't seem to find anyone in town with the correct adapter for a 1994 Discovery (OBDI). My mechanic asked me to look for an adapter for the Snap-on code reader. Any ideas?
(My discovery apparently has two connectors one under the passenger (RH) seat next to the code display and another under the steering wheel)
Phatrowles
01-09-2014 10:36 AM
