Center Console Back in - now no Cigar lighter no Heated Seats?
Old Oct 22, 2013 | 11:11 PM
Rover_Hokie's Avatar
Thank you! That is definitely something worth checking. I had a dual USB charging adapter that set basically almost flush, and it separated recently in to pieces, so could be at least part of my issue as well.
Old Dec 3, 2013 | 09:26 PM
I still have not got this resolve, so I am guessing I have something shorted out in the center console where I put it back together. Would you agree?
Old Dec 3, 2013 | 10:46 PM
dr. mordo's Avatar
Pro tip - just wire the cig lighter directly to your battery to get the wife off your back.
But be careful, the lighter itself is somewhat fragile so don't break it when you pull it apart to rewire it.
Old Dec 4, 2013 | 08:16 AM
xxdoylexx's Avatar
As stated before fuse 15, pull it replace it, if you replaced it before see if it blown again because a short will keep blowing the fuse and you will keep having the same issue.
thus, if it keeps blowing the fuse you will have to find the short. My guess would be your wives charger is shorting the system or it broke something in the lighter that is shorting the system.
I have two teenage daughter and a wife, i have visited this issue far to often.
Old Dec 4, 2013 | 08:43 AM
erietim's Avatar
Default 04 disco
hmm I have no lighter or seat heat but do have interior lights and vanity mirror light all of which are controlled by the number 15, 20 amp fuse. so help me to understand what relay and grounds y'all are talking about so that I may start the search
Old Dec 4, 2013 | 08:52 AM
erietim's Avatar
please let me know if you solve this all four out sounds like the fuse. I have my vanity light and interior lights just no lighter or heated seats fuse is 20 amp number 15 under the dash mine is good I was thinking burnt wire behind lighter for me how hard was pulling the console erietim 04 disco
Old Dec 4, 2013 | 09:05 AM
mattmo78's Avatar
I just had this issue on my wife's D2... Last time she removed her charger, it broke (the charger). Well, we failed to realize that the metal "nipple" on the charger was left inside the cig lighter. Every time she would plug something into it, it would short out.
So, my advice, make sure there is nothing wedged into the lighter itself and causing a short.
Old Dec 4, 2013 | 10:06 AM
xxdoylexx's Avatar
http://www.transcriptionsupport.com/...ayoutCabin.pdf
Use this .pdf as your fuse guide
Old Apr 1, 2014 | 09:04 PM
Richard.rover's Avatar
I have the same issue and it's driving me nuts! Any resolution on this.
Old Apr 1, 2014 | 10:48 PM
I have been busy with work and have not resolved my issue as yet. With nice weather this week, I will have to dig into it though. Rover trip to Uwharrie NF in 2 weeks, so I have to have it ready by then. Will see what I can find out and report back.
