center diff
Old Mar 20, 2019 | 06:43 PM
redwhitekat's Avatar
Default center diff
I bought a used locking centre diff a while back for my 03 diff don’t know to much history on it it’s a bit dirty with oil not sure if it was leaking or from something else but should I or have a shop reseal this differential with new gaskets etc ?
How hard is it to remove my current one from my 03 disco ?
Also opinions on just swapping out the front locking part ? I have read some people do this instead of replacing the whole diff ?
Old Mar 20, 2019 | 07:04 PM
Nigelw's Avatar
Not hard but you have to be good with the tools.
Get the new transfer box rebuilt with new bearings and seals through out as the next problem will be the work and age hardened intermediate shaft "O" ring seals that leak and then get them to fit it for you, trust me, it's worth the money unless you have a 4 post lift and a tranny jack.
Old Mar 20, 2019 | 07:50 PM
bcurtman's Avatar
I have an 03 also and I'm looking at this in the not too distant future. I've asked before but never got an answer. Can you drop the transfer case with the exhaust in place or does it have to be removed? Rave says remove...
Old Mar 20, 2019 | 08:01 PM
u definitely have to drop the exhaust and mid crossbar I don’t see how you would not. Just looking at it pisses me off
my previous house I had a 4 post hoist engine lift etc. I did all my work as far as removing and installing parts
now it’s cold and working with jack stands suck
I’m still wondering if you can just swap out the front cone or just get my used one rebuilt
Old Mar 20, 2019 | 10:10 PM
Best4x4's Avatar
I did it with the cats still in place, but middle muffler removed. Also transmission support needs to come off. Alex had a great write up on removal/re-install if I’m not mistaken or Jeff Blake.
Old Mar 20, 2019 | 10:44 PM
mollusc's Avatar
i have been pondering the process of installing the cdl from my '99 truck into the '03, so i've been referring to this write-up:
https://www.scribd.com/document/1611...te-Up-03-20-09
i also did a bunch of reading about the pros and cons of doing just the front output section versus the entire t-case. there are proponents of both approaches, of course. some argue that it can be difficult to really align the internals of the front section to the main body of the t-case and you end up with excessive whine or other noise, or possibly unnecessary wear.
switching out the entire t-case gives you the opportunity to refresh all the seals to minimise any leaks. however, if the donor case is from an earlier year, it won't have some of the internals reinforcements and other modifications that were implemented later.
my personal thinking is that when i get to the point of doing my own swap, i will pull both cases and refurbish the internals of the '03 box, as well as switching the front output section from the '99 to the '03. i hope that because i will be doing it off the vehicle it might be a little easier to ensure everything is lined up properly.
Old Mar 20, 2019 | 11:02 PM
Jeff Blake's Avatar
I rebuilt my transfer case last year.... It was a lot of work. The tolerances you're talking about are thousands of an inch. Need micrometers, a few special tools, dial indicators, press, etc. The bearing preload has to be perfect for the center differential, intermediate shaft, and input gear. Swapping front output housings is a roll of a dice whether the preload will work or not.. At best, imo, you have a transfer case with a shorter life, and at worst it'll blow out in ~200-500 miles. A few people have done it and claimed it worked... but again, if the preloads are wrong, the transfer case will still work, just not for long - not sure how many people post back if it fails down the road. There are something like 15 different shim sizes for the center diff... gives you an idea of how likely swapping front output housings will net you the right preload
Like nigel said, the primary leak point is in the intermediate shaft and o-ring, less so the various covers. In order to replace that o-ring you have to pretty much tear the box apart. The box doesn't use any gaskets... it's anaerobic sealant all the way around.
IMO just swap in another box, reseal the covers if you know they're leaking, and be on the road. Or if you want to have some fun and have a hundred hours to spare, rebuild it with new bearings, seals, diff spider gears, thrust washers, HD cross pin, shaft, etc. Land rover toolbox videos on youtube has some great videos on it, RAVE has a complete overhaul section (but it's impossible to follow without a few special LR tools)
The best transfer box is from the '04, it has CDL, interlock solenoid moved to the shifter, and I think quieter/better gears
Old Mar 21, 2019 | 08:19 AM
Thanks Jeff sounds like it can get pretty complicated in there
I wil just swap the locking diff in and see what happens.
Old Mar 25, 2019 | 01:23 PM
Question before I start tearing into this
I will install the new linkage on the locking diff but I will be taking it to a local shop to get the diff installed as I got no tools or lift
does the linkage get installed from underneath or do I hook it up from inside the car ?
Just trying to make this easier
Old Mar 25, 2019 | 01:29 PM
mollusc's Avatar
when i installed the linkage in my '99 i did it from inside. since you have to remove the entire central console anyway it's not a problem.
