Central Differential Lock
The ratio is calculated between the input shaft and the two output shafts. So turning the input shaft 10 complete revolutions, the output shafts will do just about 12 for a TC with a ratio of 1:1.211. But you can't do that with the TC in place.
BUT the ratio is written on a sticker on the side of the TC.
1) Isnt mfg std fix with a ratio? disco 1 LT230 and 2 LT230 got any diff in std gear ratio?
2) 2.5 Td5 and 4.0 disco has different auto transmission, what about transfer case between these 2 models? are they same?
3) HOw reliable overdrive is?
presise
06-19-2007 07:06 PM
