Change t/case and diffs fluid and jacking up rear of Discovery II 2000
Old May 21, 2011 | 11:30 AM
tshah209's Avatar
Default Change t/case and diffs fluid and jacking up rear of Discovery II 2000
Okay, just to confirm, the t/case and both diffs take the same fluid...Correct? I read in another thread it is recommended put 85w/140 for all three. Does that sound right? Also, how many quarts should I buy to change all three?
what do you guys thinks about using Lucas high performance heavy duty gear oil, SAE 85w-140 for all three? I can buy it at Auto Zone for $7.99 per qt.
here is the link: http://www.autozone.com/autozone/accessories/Lucas-Oil-1-qt-85W-140-high-performance-heavy-duty-gear-oil/_/N-25t1?counter=2&filterByKeyWord=Lucas+Oil&fromStrin g=search&fromWhere=Brand&itemIdentifier=693859_0_0 _[/URL]
Finally, is it okay to jack up the rear of my 2000 discovery II by going under the rear differential/pumpkin?
thanks!
Old May 21, 2011 | 11:47 AM
vandev's Avatar
Default Yes..
yes , yes and yes... If you live in a hot climate like me get the heaviest.. Dont need to jack up to do the fluids...
Have fun.. Chris
Old May 21, 2011 | 11:50 AM
mwindth's Avatar
yes, 7 quarts, from factory it came with synthetic 75W/90; Use 85W/140 for HD (towing, extreme off-roading, etc.)
I like Lucas products, is it synthetic?
Yes, though I would use jack stands under the axles before I crawled underneath.
Old May 21, 2011 | 12:31 PM
Make sure you remove the fill plugs before draining the diffs/t-case.
Old May 21, 2011 | 05:21 PM
tshah209's Avatar
Mwidth--It is not synthetic. On some other threads I learned not to used synthetics for the t-case and the diffs. you agree?
Old May 21, 2011 | 05:26 PM
JoeM5952's Avatar
Reasoning?
Old May 21, 2011 | 05:44 PM
tshah209's Avatar
I'm not sure...Maybe the recommendation was not to use synthetic for the tranny?
Old May 21, 2011 | 05:46 PM
tshah209's Avatar
mwindth, I don't really tow that lot nor do I do heavy 4wding. Should I then use the synthetic 75w/90? If so, what brand to you normally use? If it matters, this is my everyday car. I have 141,000 miles.
Old May 21, 2011 | 05:52 PM
tshah209's Avatar
Default Lucas Synthetic
Lucas sae 75w-140 synthetic gear oil???
JoeM5952's Avatar
Factory manual states for Tcase and Diffs to use Full Syn 75W/90
