Change temp control from celsius to
Old Jan 30, 2008 | 11:31 AM
Discochick's Avatar
8th Gear
Default Change temp control from celsius to
I had my engine replaced and now my heat is reading in celsius instead of farenheit. I am too lazy to read the manual. Can anyone help?
Old Jan 30, 2008 | 11:39 AM
brooksa's Avatar
Default RE: Change temp control from celsius to
I changed mine last night,
TECH TIPS
Back to Tech Tips Page
Tech Tip - Temperature Calibration on Climate Control - Fahrenheit vs. Celsius
Vehicle - Land Rover Discovery Series II [align=center]
If your temperature reads in climate control reads in degrees Celsius “C†instead of Fahrenheit “Fâ€, follow these steps to change to Fahrenheit.
[ul][*]Turn the ignition on.[*]With the climate control turned on, push and hold the recirculation button in. While holding the button in, push and hold the off button in for 3 seconds or until you hear a beep. [/ul]
The display should then change to “Fâ€. Follow these same steps to change your read-out to Celsius , if preferred.
[/align]
Old Jan 18, 2009 | 01:29 PM
SantaCruzRoverGirl's Avatar
Turn the ignition on, with the climate control turned on, push and hold the recirculation button in. While holding the button in, push and hold the OFF button in for 3 seconds or until you hear a beep.
Old Jan 18, 2009 | 01:32 PM
AK Rover's Avatar
Since the others told you how to do it I don't need to repeat it. But I will say that you need to take the time to read the owner manual. It has a lot of important information in it that will help prolong the life of the vehicle and make it more enjoyable to drive and own.
Old Jan 18, 2009 | 01:33 PM
ORIGINAL: Discochick
You have to be kidding, you're to lazy to read the manual, why should we have to do your work?
Old Apr 4, 2012 | 11:17 AM
tahoestace's Avatar
Any one know where I can buy a manual for my land rover discovery ll 2001?
Old Apr 4, 2012 | 12:36 PM
Do you really wamt to carry around 2500 pages? That's about like trying to read the Health Care bill. But you can downlaod the RAVE manual set below for free, save the whole thing or just the parts you want on PC, USB drive, etc. The D2 is in file pdf, sub directory LT.
Old Apr 4, 2012 | 05:54 PM
ralphobell's Avatar
He was asking for the owners manual, but he should download the Rave as well. Here is one place you can download the 01 Owners Manual.
2001 Land Rover Discovery Series II Owners Manual Handbook
Old Apr 4, 2012 | 07:53 PM
The RAVE contains the owner manual for most model years. And the in truck entertainment manuals. And an overhaul manual. And workshop manual. Or look at individuals ones on the on line link in my signature.
Old Dec 19, 2012 | 04:27 PM
rmcshaffry's Avatar
Default thanks for this thread
and for the reminders to download the RAVE manuals. Downloading now.
