Changed all wheel bearings and abs sensors but now have constant lights
Old Jul 7, 2021 | 02:50 PM
me 2's Avatar
Default Changed all wheel bearings and abs sensors but now have constant lights
So went around and changed all rotors, pads, wheel bearings and abs sensors. Now I have the brake light on along with the 3 amigos. Prior the 3 amigos popped up every few days maybe, but now since I did the replacements the amigos are constantly on along with the brake light. Any suggestions?
Old Jul 7, 2021 | 02:53 PM
me 2's Avatar
Note, I have checked the brake fluid level, also not sure it matters but lost the orange filter from inside the reservoir.
Old Jul 7, 2021 | 02:58 PM
mollusc's Avatar
What codes is the system showing?
Old Jul 7, 2021 | 03:02 PM
me 2's Avatar
Good question, ill check it out this evening, thanks
Old Jul 7, 2021 | 04:49 PM
me 2's Avatar
P1590 and p1441
Old Jul 7, 2021 | 07:58 PM
mln01's Avatar
Those are not ABS codes. Do you have access to a diagnostic tool that can read ABS codes on your Rover?
Old Jul 8, 2021 | 12:20 PM
jastutte's Avatar
the P1590 code is a Rough Road code related to whatever your ABS issue is.
you will need a code reader that can read ABS codes and reset as needed.
Edit: spelling
Old Jul 8, 2021 | 02:20 PM
JUKE179r's Avatar
That orange/yellow filter screen is needed inside of the brake fluid reservoir to catch crap from entering the braking system.
Old Jul 8, 2021 | 05:04 PM
me 2's Avatar
I don’t have a abs scan tool, any suggestions on a good tool and where to get it? Ty
Old Jul 8, 2021 | 05:26 PM
Best4x4's Avatar
iCarsoft LRII is a good unit for a D2/LR3/RRS/LR4/RR scantool.
