Changed Coil Packs and Wires, Now it Won't Run
Old Dec 26, 2020 | 05:30 AM
  #31
The Deputy's Avatar
Originally Posted by NickS
Just saw your video I'm betting on a vacuum leak have someone crank it and spray the lines with some break clean or quick start. If it idles up then there's something loose or not tight
Did you clean the intake gasket surfaces and use a new gasket?
Of course it's speculation without seeing it.
Also, Nick nailed it in this post. Whenever someone makes a suggestion...proper thing is to follow up on it. Odds are, they're ran into this before or have seen. Sounds like you didn't get the intake setted into guides properly and simply tighten it...and stopped when you felt resistance. Regardless, at least you are on the road again! And just when you thought you were to old to believe in Santa..he delivers a gift...lol.
Old Dec 26, 2020 | 09:33 AM
  #32
Sandman614's Avatar
yep, I bet it purrs with the intake bolted down. Crazy that no one thought of that!
Old Dec 27, 2020 | 12:37 AM
  #33
LRScott's Avatar
Sorry, I get tunnel vision sometimes... I don't know why but I was under the impression that as long as the intake was snug against the gasket it would run ok, not great, but ok... so that's why I shrugged off vacuum leaks as a culprit. Now I realize just how important it is to have everything sealed up properly. Thanks for the patience .
Old Dec 27, 2020 | 03:30 AM
  #34
The Deputy's Avatar
"You live, you learn." It's what most folks call experience. Now that you've experienced this issue, odds are...it won't happen again. At least you stayed with it and finally got her running...which is the main thing.
Hey, you stay with it long enough and keep hanging around this Land Rover community...and you'll be giving advice soon.
0304Disco
Sep 19, 2023 04:14 PM
Tony Luna
Mar 27, 2020 09:52 PM
robersonb
Oct 28, 2018 07:12 PM
ruggles
Jun 23, 2010 06:31 PM
hendoc3
Jul 19, 2007 06:02 PM
