changing battery
Im going to change the battery in our 2001 disco soon,just read a post that says you will loose your raido. and I have no idea what the code is or how to find it without going to the dealer. If this is true I was thinking of using a spare battery and using jumper leads to parallel the spare battery to the terminals so it never looses power. Some one let me know if this is wise or a silly idea
Thats great,never thought of the cig lighter.I have a 12 volt charger with a cig input....I think Ill try it even with the key on....Hopefully it puts out enough to power whatever the key "on" has powered up.
This site is is a great find....Im sure Ill have more questions soon...Thanks Again
Your idea should work just fine, assuming the spare battery if fully charged. When I had to replace my battery last winter, I borrowed the jump pack from where I work, to keep 12 volts on the battery cables while I pulled and replaced the battery. I have my radio code on my home computer, but I didn't want to drive home from work without tunes.
Just be very gentle moving the cables, because you don't want the clamps from the parallel battery to come off the terminals during the process.
If you do manage to lose your radio, all you should have to do is fax the dealer a copy of your title, and drivers license, to verify ownership.
The only downfall with that is that if the new battery is a little undercharged the instant load from hooking the cables back up might fry the alternator.
Yeah, on my 03 I was amazed that all of my presets were still there.... it's a freelander style cd player, so no code anyway, but I was still impressed.
