Changing the center dash
Old Jul 9, 2017 | 07:32 PM
Luckyjayb's Avatar
Originally Posted by DKPhoto
Hey Lucky do you have the HK system in yours? Reason I'm asking is I replaced my HU and the engine noise is horrible. After checking all the grounds I traced it back to the factory amp as the source, so it looks like ill need to replace the amp. From what Ive researched its no easy task to put in a aftermarket amp because it requires rewiring the system. Do you have any experience with this?
i got the factory hk premium sound system and even with the engine shut off and the volume down, there is a humm. I've added a ton of amps in my days and it is very easy man. Find you a good amp you want and get a good wiring kit. The only thing that is hard is wiring the power to the battery and properly hiding it (I'm OCD) and the new head unit should have pre amp outs in the back. I'm gonna end up swapping everything out for Memphis car audio and then a Memphis marine amp in case the sunroofs fail me at a later date!!! For wiring kits and such, check out http://www.sonicelectronix.com they have the best prices and ship quick as hell from cali. If you make a cart and sign up and don't check out, they will usually send you a coupon for 5-10% off a day or two later. I've always used them for my stuff. They used to carry Memphis so I have to go elsewhere now for the speakers but they carry 99% of the brands. I got the head unit and the adapter to keep my steering wheel controls and it came with a free harness and the fitting kit and I paid like $139.99 with 2 day shipping!!!
Old Jul 9, 2017 | 07:34 PM
Luckyjayb's Avatar
And your amp shouldn't be hooked up like the cd changer. If you want to get rid of your amp, sonic electronix has a Sony head unit with a 140 watt amp built in where you can remove your amp all together
Old Jul 9, 2017 | 08:33 PM
DKPhoto's Avatar
I don't want to hijack your thread but lets say I replace my amp, don't I have to run new speaker wires and then put in 4 crossovers? After looking through the Rave electrical diagrams it looks like the factory amp is not wired in such a way that I could use the existing wiring.
Right now I have a pioneer HU that I could run the speakers off (idk how many watts is its) but I would still need crossovers to power the 4 front tweeters and 2 bass speakers and then 2 crossovers for the back 2 tweets and 2 bass speakers. (The rear subs have been eliminated) Im planning on doing a new sub eventually with its own amp.
Old Jul 9, 2017 | 08:55 PM
Luckyjayb's Avatar
the aftermark amp would only power the aftermarket sub. The only way to power the speakers would be using the crossovers, or using a head unit with a built in amp.
Old Jul 11, 2017 | 06:14 PM
DKPhoto's Avatar
I think I understand, I'm going to give it a go with the aftermarket amp. I might shoot you a message on here if I can't figure it out if you don't mind.
Old Jul 11, 2017 | 09:03 PM
Luckyjayb's Avatar
Originally Posted by Friday Night Disco
I removed my whole console today, cake
oh...you don't have a legit CDL until you get that sticker updated
yea I need to get one. U got the link where you got the one for tricky dicky? Abran hooked me up with the cdl **** at least!
Old Jul 11, 2017 | 11:05 PM
Friday Night Disco's Avatar
Mine came with the shifter from LRDirect. However, I did provide you with a template for a kick *** CDL sticker
Old Jul 12, 2017 | 01:46 PM
Luckyjayb's Avatar
yea I remember that one
Old Jul 12, 2017 | 02:44 PM
I might have an extra one kicking around, it is not the same as the factory but, it has the CDL icons. Check my photo gallery.
Old Jul 13, 2017 | 01:37 PM
You can have the sticker on the left, at least it has the diff icons on it.
