changing diff fluid
Old 07-23-2009, 09:34 AM
chad420's Avatar
Default changing diff fluid
Reading the repair manuel and it says to change the o-ring on the diff when you change the fluid. Is this neccessary or can i use the old one and be fine????
Old 07-23-2009, 09:45 AM
First, what year, model and mileage?
Have you ever done something like this before, what gear oil are you using?
Old 07-23-2009, 02:08 PM
chad420's Avatar
2001 disco II le...102,000 miles...I dont do any off roading so im using 75-90 gear oil....my cousin is a mechanic si hes helping me....shouldn't be too tough
Old 07-23-2009, 02:49 PM
So, on a D2, the fill plug is plastic, prone to breaking, and really should be replaced with one of the solid metal or brass plugs.
As for the oil, consider going heavier, to the 75W/140 for extra wear protection for your spider gears.
Also check each drain plug for metal chunks on the magnet.
Do the same thing with the t/case, using the same oil and inspection, 7 quarts in all.
Old 07-23-2009, 02:54 PM
lipadj46's Avatar
Is there any downside to using the heavier gear oil in discos? I've been using the 75W90.
Old 07-23-2009, 03:01 PM
No downside I can see, everything runs quieter, less metal mud on the drain plugs so less wear and the cold here in Colorado sure doesn't seem to be an issue. The t/case has the biggest change, much quieter.
JBEGIN's Avatar
harder to pump out, depending on what method you use to get the gear oil into the diffs./T-Case...
Old 07-23-2009, 03:15 PM
chad420's Avatar
where can i pick up the plugs and is there an o-ring i should buy also.....
Old 07-23-2009, 03:19 PM
lipadj46's Avatar
Well I only have changing the differentials and transfer case oil left to do on my list. I will try the heavier oil this time.
Old 07-23-2009, 03:33 PM
khuds308's Avatar
expedition exchange sells the brass plugs. i got a couple of them because i am a neanderthal and shredded the stock plastic one on my DII. they are worth there weight in gold in my opinion. oh and they come with the O-ring on there.
Quick Reply: changing diff fluid
