Changing gear ratios, is it worth it?
Old Feb 20, 2019 | 07:55 PM
Dsport's Avatar
Default Changing gear ratios, is it worth it?
hey guys, im considering swapping my ratios, from factory 3.54 to 4.11’s. I have 33” tires and a big rack (no pun intended). My truck absolutely sucks uphills. Anything paved with a grade, mountain passes, etc, forget about it. I feel like I’m going to blow a head gasket, and the truck hates life.
For ~$760 in parts, is it worth it? Does it make a noticeable difference?
A quick calculation gives the approx rpms of a stock d2 in 4th gear as:
2525rpms @ 70mph
2886rpms @ 80mph
For stock gearing and 33”s
2235rpms @ 70mph
2554rpms @ 80mph
For 4.11’s and 33”s
2602rpms @ 70mph
2974rpms @ 80mph
So currently I’m at about 290rpms less than what I should be at 70mph. The 4.11’s would be about 77rpms more than a factory rover at 70mph, so pretty close to factory.
Any thoughts? Obviously it’s not the flat freeway stuff I have problems with or short grade climbs <30min, but I can no longer take my truck up the longer mountain passes for fear of blowing the motor.
Old Feb 20, 2019 | 08:23 PM
Frank4's Avatar
I’ve been considering this as well. I have a similar setup ( 33”s, rack, etc.) and have been wondering if it’s worth it.
Old Feb 21, 2019 | 07:35 AM
Nigelw's Avatar
2525rpms @ 70mph
2886rpms @ 80mph
2235rpms @ 70mph
2554rpms @ 80mph
For 4.11’s and 33”s
2602rpms @ 70mph
2974rpms @ 80mph
Yes, 100% worth the swap, 33" tyres are +13.6% gearing increase and the drag fro the rack won't be helping you out at all.
​​​​​​I am about to order up the ring and pinions for my own 200Tdi engined Discovery.
Old Feb 21, 2019 | 08:19 AM
The Deputy's Avatar
I'd say you are right there for a swap, 33's are the straw that breaks the camel's back, as far as I'm concerned. Missed a set of 4:11 gears with lockers last year, and kick myself every time I think about it.
Brian.
Old Feb 21, 2019 | 10:55 AM
Frank4's Avatar
Have you done a hearing swap or planning on it?
Old Feb 21, 2019 | 02:31 PM
From my experience with the 2 lr3 the stock one feels like a race car with stick tires compared to my lifted with rack and 32.5" tires. I would consider regearing if their was a option. I drove a regeared Disco on 35s and it felt really good still
Old Feb 21, 2019 | 02:48 PM
Dsport's Avatar
can you clarify? I think there are a couple typos in there. Are you talking disco 2 or LR3/disco 3?
Old Feb 21, 2019 | 03:44 PM
Stoney83's Avatar
Im not sure it would be any cheaper with the labor included.
But Ashcroft transmission has a ratio change on the transfer case for 275 pounds ($360).
That would change the overall gearing and instead of tearing apart 2 axles it would be one transfer case.
Old Feb 21, 2019 | 04:40 PM
Frank4's Avatar
Jesus, can someone who has actually done this please add something!?! PLEASE!?!?
Old Feb 21, 2019 | 05:14 PM
Dsport's Avatar
^^^what he said, please!
Isn’t this interesting? I’ve seen gear ratio changes recommended countless times in the “what tire size should I get” type threads. yet, not many who have actually gone through with it. I stack that up to most d1/d2/lr3/rr classic owners being thrifty do-it-yourselfer types. And an expensive parts change which requires speciality knowledge/tools, doesn’t really fit the demographic.
