Cheap 36mm wrench for viscous fan removal
I posted this a few weeks ago but I actually want to confirm that this wrench will fit on a DII's viscous fan nut. Just barely but it is a nice beefy wrench compared to the sheet metal stamped ford wrench, cheaper too.
http://www.northerntool.com/webapp/w...2595_200322595
I actually was able to put the wrench on the nut (after I sprayed with PB blaster overnight and ran engine to temp.) and hit it with a bat and loosen the nut without holding the pump with a strap wrench or anything.
36mm, 36mmwrench, cheap, fan, land, landrover, removal, removel, rover, sheetmetalwrench, tool, toolwrench, viscous, viscouse, wrench
