Cheap fix for subwoofer
Old Apr 16, 2010 | 10:46 PM
gowest's Avatar
I love this fix and will look at the item at Wal Mart tmro, but, you guys know you can get a used oe sub for $40-50....
Old Jun 7, 2010 | 03:35 PM
jrover99's Avatar
Default Great fix
went to walmart but they do not sell them in 6 1/2 inch subs but the salesman in best buy told me to go to pep boys and they had it. it was the whole sub box for 19.99 what a deal took it home removed speakers from sub box and installed in my 1999 disco 2 and it sounds great. Awsome fix cheap and good Thanks Jim
Old Jun 7, 2010 | 03:58 PM
okdiscoguy's Avatar
I epoxied in a couple of those, but wasn't quite happy enough with it. I found a custom LR box with the Logo made into the leather on CL for $20. I threw in some 10's and added an amp. I just put a couple of tears in it last week hauling wood =(. Still hits hard, though.
Old Jun 7, 2010 | 04:32 PM
johnsoax's Avatar
Originally Posted by wynhd
So the way I understand this is, that its a plug and play, I saw in the links that the factory amp is in the rear door, was it relcated there or has it always been there? Is our system powered enough to push this amp and is ours 4ohms? Mine is sounding distorted and a cheap good fix would be welcome.
That link is of my flickr set.
I relocated the amp into the door. It used to be mounted to the magnets on the old speakers. I mounted it to the cross brace inside the door.
They still sound great, but I think the amp may have worked itself loose. Need to get it back open and check, as something is rattling around in there now.
Old Nov 26, 2011 | 08:33 AM
Joel 2000 Discovery's Avatar
I bought the box from Amazon.com and replaced the speakers in my 2000 Discovery 2 but get no sound from them. Originally, I didn't have the amp mounted on the speakers like yours was. Will that make a difference?
Old Nov 30, 2011 | 01:08 PM
Fuzecutter's Avatar
8th Gear
The name brand is different, but the system is the same at Walmart...I took it apart and replaced my wasted subs...the new ones sound great and I wired in one of the tweeters. I paid $30...comes out to $10 per speaker.
Old Dec 25, 2011 | 04:46 PM
colddude's Avatar
4th Gear
Default Wiring details
So I bought the same $20 boombox and removed the speakers to replace the subs in my 98 D1 LSE. The fit is perfect as noted by others...but please help clarify how to wire the new subs. My 98 D1 has under the driverseat amp, so at the rear door are there just 2 subs and wires (no amp).
The original subs have 4 wires each - red/red-blk, blk/blk-wht. I understand they are dual voice coil subs. The new subs are single coil, having just +/1 terminals.
How did you wire up the new subs from the $20 Wal-mart box?
Old Dec 25, 2011 | 04:47 PM
colddude's Avatar
4th Gear
I mean +/- terminals
Old Dec 26, 2011 | 07:23 PM
colddude's Avatar
4th Gear
Default 98 D1 rear door subs wiring
Well, I took a guess, and believe I've got the right connections now...here are the details.
The original factory subs were dual voice coil speakers. Each coil measures ~2ohm. I figure the factory amp probably is providing 4ohm drive, so the 2 coils are likely to be connected in series inside the amp. I can't tell for sure of this, there are 8 wires (4 per sub) going to the rear door connector. Per sub, the wire colors are Red/Red-Blk, Blk/Blk-Wht.
The cheap Wal-mart box's subs are single-coil, measured ~4ohm with +/- terminals. From one set of the wires, I connected the Red wire to +, and the Blk-Wht wire to -. I taped up the spare wires as no-connect. I did exactly the same for the other sub.
Both new subs sound good, hopefully this will last a while.
SuperSport
Jan 25, 2013 10:32 PM
Chris528
May 7, 2010 08:37 PM
Wanix
Oct 16, 2008 05:39 PM
Rich 00 DISCO
Sep 7, 2008 09:31 PM
97DISCOIDAHO
Aug 28, 2006 03:21 AM
