Cheap insurance to protect the radio from the rainroof...
Old Aug 30, 2024 | 08:33 AM
Externet's Avatar
Lightbulb Cheap insurance to protect the radio from the rainroof...
Hi.
Before the rainroof damages your tunes : cover the top of the radio.
If concerned about ventilation/cooling of the radio, the high-end model radio with the amplifier under the seat doesn't get hot. The low-end may, but will not be hotter than a summer day under the sun. And better than a dead corroded wet radio.
Old Aug 30, 2024 | 05:05 PM
Harvlr's Avatar
Well I know you’re way more up on electronics than me, but I would be really leery about blocking the ventilation.
Old Aug 30, 2024 | 05:12 PM
Externet's Avatar
Valid point. Sides and bottom were not covered. Today was 96F, behaved fine.
Old Aug 30, 2024 | 06:54 PM
Discorama's Avatar
Also not wrong to re-coat the PCBs to protect them against (electrolytic) corrosion. Moisture can be present in such an application, that's why PCBs in automotive applications have to be sealed always, especially after some repair work. The coating can also crack over time because of extreme temperature swings and vibration. I use this spray conformal coating which is easy to apply. It's also available as fluid: https://mgchemicals.com/category/con...rmal-coatings/
Old Aug 31, 2024 | 05:17 PM
Extinct's Avatar
This
Old Sep 1, 2024 | 09:39 AM
Externet's Avatar
Conformal coating is a great internal protection - too late prevention.
Done after the radio had to be dismantled from the damage from the rainroof dripping and after successfully repaired... [If not repaired, is is useless to coat]. Not before the damage happens.
Nobody removes and dismantles a good working dry radio to apply the coating to each internal board surface, component, solder joint and crevices. So conformal coating is insurance to avoid the second repair.
The radio is always powered by a permanent +12VBAT connection. So even when not turned on, water ingress does its electrolytic diarrhea to circuitry.
LLLL322
Range Rover L322 (3rd Gen)
Apr 23, 2023 05:16 PM
elboy0712
Oct 22, 2017 09:33 PM
Toran
Feb 11, 2017 08:49 AM
puchita
Aug 17, 2008 08:33 AM
