Cheapest steelies for a DII
Old Mar 11, 2011 | 11:17 AM
RjBu's Avatar
Default Cheapest steelies for a DII
Hey guys
I am finally able to get rid of my 18's and move on down to some proper 16's... I have some leads on the OEM 16's but would much rather get some steelies. I know of the Nato's through AB but are there any other more affordable sets that I should be considering?
Old Mar 11, 2011 | 11:44 AM
RjBu's Avatar
Ok it appears that BMW use a similar bolt pattern 4 * 120 but the holes for the studs are 12mm and the DII is 14mm... Can i simply use a drill press w a 14mm bit and tap the holes myself? I found a set of black steels for 75$.
Old Mar 11, 2011 | 11:51 AM
NiteTrain's Avatar
you mean 5 * 120?
Old Mar 11, 2011 | 12:04 PM
RjBu's Avatar
You got me! Yeah 5*120
Old Mar 11, 2011 | 01:03 PM
yloDiscoII's Avatar
$100 each
http://www.okoffroad.com/stuff-wheel-lr.htm
Old Mar 11, 2011 | 06:24 PM
jafir's Avatar
http://www.roverparts.com/Parts/3030A.cfm
These appear to be on sale. I sent an e-mail asking why it says you cannot use over sized tires. This was the response "The wheels are 1 1/4" offset so bigger tires catch on the body. " I wonder if they would work for a narrower tires, but taller, like 235/85R16. That's the reason I'm looking for 7" wheels in the first place.
I wonder if these wheels and the okoffroad wheels are the same wheels....
Old Mar 12, 2011 | 03:24 PM
texmbr's Avatar
Need to check out the steelies and tires in the classified. Sure wish I lived closer I would be counting out the bucks.
Old Mar 12, 2011 | 04:21 PM
racingwoody's Avatar
https://landroverforums.com/forum/sh...ad.php?t=39082
Check me out!
timdunbar
Oct 9, 2010 05:57 PM
BimmerFreak
Sep 18, 2010 05:20 PM
sloppyjoe
Aug 24, 2010 08:44 PM
leadoverdistance
Sep 22, 2007 11:15 PM
SnowmanJon
Jun 23, 2007 11:37 PM
