check engine light after Sea Foam
Old Dec 28, 2006 | 03:15 PM
bigugly82's Avatar
Default check engine light after Sea Foam
Hey guys,
I just Sea Foam-ed my '03 Disco (TONS OF SMOKE!); but now my check engine light is on. Should I be worried? or will it go off once the sea foam is totally out of the system??
thanks.
Old Dec 28, 2006 | 03:58 PM
Default RE: check engine light after Sea Foam
Did you stall the engine while putting in the SeaFoam? If it is put in too quickly, in less the 2 or 3 minutes, youe idle will drop or the engine may stall causing the ligh to come on. It will probably go off in a couple of start cycles.
I wouldn't worry about the SeaFoam damaging your engine.
Give it a couple of days.
Mike
Old Dec 28, 2006 | 04:03 PM
bigugly82's Avatar
It did stall.
Thanks Mike. That's what I thought. I'll let you know if it resets itself.
Thanks Again.
Ugly
Old Dec 29, 2006 | 10:32 PM
askewm's Avatar
Uhh...at the risk ofsounding ignorant, what is SeaFoam? (I assume we are not talking about what comes from the Sea)
Old Dec 30, 2006 | 09:14 AM
JBRIII's Avatar
It's an additive/cleaner that you can add to your fuel or suck directly into your intakle through the vacuum lines. supposed to clean carbon deposits. never used it on my car, but mix it with my gas/oil on my duck boat engine as a fuel stabilizer and cleaner.
Old Dec 30, 2006 | 03:14 PM
jmang's Avatar
does it work, or is there something better?
Old Dec 30, 2006 | 09:18 PM
Oh yes, it works and there are a few others that are better but way more sexpesive.
Mike
Old Dec 31, 2006 | 03:18 AM
bigugly82's Avatar
Disco Mike,
Check engine light quit showing up yesterday. My '03 Disco purr's like a big blue British kitty.
And for everyone else who has never done it. It works fantastic (and price about $4-ish), but there is a TON of smoke. I did it behind the house on a windy day so it wasn't that bad. But I think if it would have been a still day I might have killed the canary.
Old Dec 31, 2006 | 11:17 AM
Glad to hear it cleared it self, never any doubt, just can't poor the stuff in too quick, it will stall the engine and throw a code.
Did you put a can in the gas tank, if not do that still and it will continue to clean up the system.
Mike
Old Jan 2, 2007 | 06:49 AM
TrickyWhu's Avatar
Where in the engine are the vacuum lines, I added the seafoam to my gas and oil but wanted to clean my carboretor as well. And, if anyone is out there who knows, how do you propery clean the MAF sensors?
Thanks
Paul
