Check engine light on disco 2
Lol she give me like 8 storage codes and 3 not storage, letme get the scaner hold on... P0130 P0150 and P0174 and P0171 and P0734 Now i been getting this p0734 since i went into that water hole, i did check all (my ground cables meaning my negative -) fronthe motor fuse boxes chassis thinking that coud be some ground problem also put diaelectric grease to every connector and plug the have to do to the engine computer, and actually i make the engine runn beautifull but i get thos codes, but idle is better than ever.....
LOL, Thanks!!!!! MMMMmm letme see, Ok Spark plugs i replace about 2 years, ignition wires never but they are fine i check those wires with the engine runninig in idle on a very dark place and there is not sprk jumping from place to place so i'm ok with the wires, I did replace the ignition coils about 1 monht ago!!!
Yeah, i know what you said, i think is time for a tune up, ok i need ingnition wires, spark plugs, air filter and oil change, Already replace about a month ago, valve cover gasket, the pvc kit with new house, ignition coils, new front cover seal.... the brakes have to wait for now
P0130 O2 sensor circuit malfunction (bank 1, sensor 1) Front sensor LH bank stoichiometric ratio outside
operating band
P0150 O2 sensor circuit malfunction (bank 2, sensor 1) Front sensor RH bank stoichiometric ratio outside
operating band
P0174 lean condition on b2 but this is caused by bad O2 sensors
P0171 lean condition on b1 but this is caused by bad O2 sensors
P0734 transmission code
So long story short those 2 front O2 sensors are bad. AB has been known to send out bad O2 sensors don't be afraid to ask for replacements
operating band
operating band
are you leaking coolant? just want to make sure it wasnt leaking coolant that caused you O2's to fail... in the meantime get on the phone to AB and see if they will replace the two front O2's, you need an ABS scanner to get the ABS code for the three amigos (TC, HDC, ABS) and then bring us that code. Sometimes when you clear the Three Amgios the Rough Road sensor error will go with it, if not the ABS scanner will tell us the cause, could be a false wheel speed sensor, ABS speed sensor or EAS ride height sensor.
Yea! i'm not worry about theP0734 bcs it coud be related to the 02 sensors also. Do you think atlantic british can warranty those o2 for me? it's been abot 2 years since i purchase this 4 o2 sensores...
