Check engine light help on Disco 2
I have a 2000 Disco 2 with 109,000 miles. I've been fighting a check engine light. I've searched and done the followed.
1-error code was p0174 for bank 2 lean condition (started to idle rough when in gear)
2-I removed my K&N filter and put in a paper filter and check for vacuum leaks (did this with visual inspection and spraying carb cleaner to see if idle increases). Found nothing.
3-cleaned my maf (which in turn made it idle even rougher)
4-replaced the maf with a used item off ebay (made the idle better)
5-replaced my front o2 sensors (with the miles, figured I needed this with the miles on it. It now runs better then I can remember.
6-cleared the code
7-light came back on and checked it, it's now po171 for bank 1 lean condition
8-decided I should have done all 4 02's at the same time, so I got the downstream o2's and replaced them.
9-cleared the code
10-po0171 is now back.
I hate dealers so anything that can keep me from going to them would be greatly appreciated!
6-cleared the code
9-cleared the code
Update, I went through and re-checked/tightened all clamps for my vaccum lines and made sure they are on tight. Went and check my codes and it's p0174 for bank 2 now. I really don't know what else to look at. It's running great. I really need some help.
Thanks!
Thanks!
Update folks. I had a broken exhaust stud on the left manifold. I pulled the manifold, checked for cracks, no cracks on it. Replaced the gaskets, re-installed and tightened it. Cleared the p0171 code and drove 30 miles and it's back. Anything else people?
