To Check... Or Not To Check.
Old Aug 1, 2007 | 11:06 AM
tads's Avatar
Default To Check... Or Not To Check.
After a long trip to Atlanta, during the leg home, my Check Engine light illuminated. I checked it with the scanner. 02 Sensor. So, I've been preparing to do the switcharoo when this morning the light would not come on! No light. I've shut down and re-started a couple of times today and I've got nothing.
Should I still assume that the sensor is bad?
Old Aug 1, 2007 | 11:09 AM
okdiscoguy's Avatar
Default RE: To Check... Or Not To Check.
how many miles? they are bad after about 60K, and always replace all of them at a time if they are old... Could have been a loose connection.
Old Aug 1, 2007 | 11:57 AM
tads's Avatar
96 SE7 with just under 140,000 miles. I don't know when they were changed last.
Old Aug 1, 2007 | 11:59 AM
okdiscoguy's Avatar
I would replace all of them. You will get a bump in mileage and performance. I think DiscoMike has a link for them for around $70 a piece.
Old Aug 1, 2007 | 03:26 PM
2000 Disco 2 SD7's Avatar
AtlanticBritish.com has O2 sensors for $69.95 ea. - front and rear
Old Aug 1, 2007 | 04:04 PM
Landzu's Avatar
ORIGINAL: 2000 Disco 2 SD7
O2 sensors for Disco I are $115 to $129 each it would be nice $70 .
Old Aug 1, 2007 | 06:01 PM
okdiscoguy's Avatar
MIKE! Where are you?
I thought he found some for $70. probably for a D2 though. I could have sworn it was for a D1. I need to do mine, but am not ready to spent the $$ on it yet. Has to hit $4 a gallon before I can...
Old Aug 2, 2007 | 07:01 AM
Landzu's Avatar
My Disco I is a pre avd evap system.
I got mine from Atlantic British for $110 on sell.(02sensors)
The Disco II' s 02 sensors are $70.
If some one does find Disco I's 02 sensors cheaper let everyone know.
Old Aug 2, 2007 | 07:23 AM
khandrh's Avatar
How often should the 02 Sensors be replaced..
Old Aug 2, 2007 | 07:41 AM
Landzu's Avatar
02 sensors on my Disco I owners manual shows 82,500 miles for the first service interval.
I'm not sure on the next service time for mine.
You can call a dealer.
