Checking Transmission Fluid
Old Jan 26, 2008 | 03:44 PM
jkid's Avatar
Default Checking Transmission Fluid
So I'm still getting this PO734 engine code every couple of weeks and I figured I would check my transmission fluid since I haven't looked at itsince changing it a few months ago. I unplugged the fill plug and about half a quart probably came gushingout. I assume this is because the fluid was still pretty warm (it had been sitting for about 1.5 hours in 30 deg weather since being driven) and it was cold when I had changed it. So, I forget, is it supposed to be checked when cold (it's about35 degrees out now) or when warm after being driven? Seems like every other tranny is checked when warm. I can't believe the owner's manual says nothing about checkingthe fluid.Could the fluid level even throw a code?
Old Jan 26, 2008 | 04:38 PM
Default RE: Checking Transmission Fluid
You are supposed to check and refill the tranny when the engine has been running for about 2 minutes, check it in park.
The 734 code has nothing to do with the fluid level, it is a 4th. gear out of ratio problem usually associated with a failing MAF.
Old Jan 26, 2008 | 04:45 PM
jkid's Avatar
Mike, I think that I read a post somewhere when you said that a weak battery could cause a fault in the ecu and give this code. Was that you, I can't remember? My battery reads only 12.3 volts, so maybe it could give a code if the battery drops low enough when cold and has a big draw on it?? My truck runs fine, it just gives the code every couple of weeks.
Old Jan 26, 2008 | 05:47 PM
If tested properly, a battery/alternator should be 13.6 to 14.4, or you will have problems.
Old Jan 26, 2008 | 08:08 PM
RamblingMan's Avatar
How do you test properly, just so I can see if I'm doing it right.
RM
Old Jan 26, 2008 | 08:11 PM
Take it down to one of the local auto parts stores and have them do a free load test on both the alternator and battery.
Athana
Jun 8, 2019 10:23 AM
DUBLJDISCO2
Jan 6, 2012 06:29 PM
NiteTrain
Jan 24, 2011 03:31 PM
nickd503
May 18, 2009 08:49 PM
barrios
Aug 2, 2005 12:15 AM
