Chirp in driveline - diagnostic help please!
Old Dec 2, 2015 | 02:19 PM
batard's Avatar
Found a local shop that will do full rebuild, balance and paint for $260.00. After reading over the rebuild-it-yourself threads, that seems like a bargain. The parts alone from Napa are $120+
Three decent UJs will cost you around $100 (Land Rover Universal Joint - Propeller Shaft (Part # TVC100010)), and it's extremely easy to DIY if you have a large C-clamp, some sockets and an internal c-clip tool. The 27mm socket for Disco lugs turns out to be the perfect size to act as a receiver cup for the UJs. Provided you don't mess with the center bearing in the cardon joint (I had a ton of trouble with it and ended up having to get a new shaft as a result), it's worth doing yourself, IMO.
Getting a balancing done does provide some extra peace of mind. Not sure if that'd be worth ~$160 to me, but it might be to you.
Old Dec 2, 2015 | 04:37 PM
ATLDisco's Avatar
The centering ball is precisely why I'd prefer to get it done at a shop.
To me, replacing the U-joints and not the centering ball defeats the purpose of the exercise.
Plus, the 2 year warranty is handy as well.
I have the tools to do so, but the limiting factor at the moment is time....and I need this back on the road soon.
I usually do all my own wrenching, but I'm learning to send *some* stuff out the door for the sake of my sanity.
Old Dec 3, 2015 | 07:14 AM
drowssap's Avatar
why would you rebuild a front driveshaft and not do the center bearing? which is the cause of most front failures
Old Dec 3, 2015 | 07:20 AM
batard's Avatar
I don't get it -- how is the center bearing the cause of most failures?
Old Dec 3, 2015 | 07:28 AM
dgi 07's Avatar
It doesnt get greased often enough....
The joints fail often, but when its a catastrophic failure, its usually the ball giving up the ghost and dragging everyone down with it.
Old Dec 3, 2015 | 07:31 AM
batard's Avatar
So when you rebuild it you obviously grease it. If it's still moving around freely and is properly greased, I don't understand what the issue is with not replacing it.
Old Dec 3, 2015 | 08:02 AM
Charlie_V's Avatar
I have a few front driveshafts... A couple of stock ones and a couple of HD ones that I got later, and I've never seen grease come out of the centering ball, nor a fitting to grease them (unless grease migrates from the u joints to the centering ball, in which case my grease has never made that trip insofar as I have never seen it come out of the ball). I'm not contradicting the previous post... I really want to know how to grease the centering ball. Driveshafts are expensive!
Old Dec 3, 2015 | 08:10 AM
dgi 07's Avatar
Post #5
https://landroverforums.com/forum/di...-failed-31383/
It can be done. Its just a monumental pain in the a$$.
Old Dec 3, 2015 | 08:16 AM
ZGPhoto's Avatar
....for real?
If I were to rebuild a shaft and had to choose, I would replace the centering ball and not the U joints.
Old Dec 3, 2015 | 10:55 AM
batard's Avatar
Why? Maybe I'm dense, but I don't understand how regreasing a working, non-defective center ball is a bad idea.
