Choosing Lift and Tires for Discovery 2 TD5 2003: Advice and Recommendation
Hello everyone!
I'm new here and haven't fully figured out the search functionality on the forum yet, so I decided to start a new topic. I recently acquired a 2003 Land Rover Discovery 2 TD5 in completely stock condition and am now looking for optimal upgrades.
My goal is to lift the suspension by 2 inches with the installation of R16 metal wheels and All Terrain tires sized 265/75 R16 or similar. I plan to use the car mainly for city driving, traveling, and nature outings, occasionally for light off-roading.
Questions for the community:
1. Lift kit manufacturer choice: Which manufacturer of the 2-inch lift kit would you recommend?
2. Kit type: Do I need a kit for medium (Medium Duty) or heavy (Heavy Duty) loads, considering that most of the time the car will be nearly empty?
3. Suspension system: Should I switch from air suspension to springs (Air to Spring) or keep the rear air suspension?
4. Tire choice: What R16 tires would be suitable for daily driving, traveling, and light off-roading, considering they need to be adapted for winter, snow, rain, and mud, but the main use is on asphalt?
5. Necessary wheel offset: How to determine the suitable offset for R16 wheels so that after the lift, the tires do not rub at full steering lock and do not protrude beyond the fenders? I'm considering 8J wheels with an ET-0. Are there alternatives to avoid using spacers and keep the wheels within the arches?
I would be genuinely grateful for any advice and recommendations! If you have photos of your Discovery with similar modifications, I'd love to see them!
They're all honestly pretty good. Decide depending on budget.
Medium
Pros and cons to each. If your air system is in good order I'd consider keeping it and using spacers. If you want rugged reliability switch to coils.
Falken Wildpeak AT is my go to recommendation.
0 offset will stick out further than factory. I'd personally stick within 10mm of stock offset - don't recall the spec off hand.
Medium
Gripen (03-05-2024)
As longs as springs and shocks are good I would not replace them. Stock height is completely sufficient for your driving plans. Slightly bigger AT tires are helpful. Since you have rear air suspension, you can adjust for added weight. I have stock suspension, 30.5" (Nitto Terra Grappler), rear coils with added air bags (to prevent sagging in the rear) and go fully loaded with five people on longer camping trips on dirt roads and easy trails. Clearance was never a problem.
