Cleaning a MAF sensor
Yes, a lot of people have cleaned the MAF on their DII. What did they use? Most who did it successfully started by using Land Rover Forums - Land Rover Enthusiast Forum - Search Forums.
I've never known anyone clean them to last longterm as they are a hotwire measurement system and very fragile. There are cleaners but by the time they register a code they are often past cleaning or refurb but sometimes a clean works short term but rarely the MAF sensor lasts too long. Be very careful what you use to clean the wire and never handle the wire. There are spray products available for this cleaning process. Good luck.
"Has anybody had any success with cleaning their MAF sensors? I previously ran a search on this forum and found lots of references to MAF cleaner spray, a product which appears to be unavailable in the Middle East".
I was having a p0734 code showing up and someone suggested to replace the MAF.. Bought one off eBay but in the mean time I clean the old one w brake clean and and the issue went away. Unfortunately I started getting a#4 cyl misfire immediately after. Go figure! Not sure it's related but today went to install the new MAF and the fpos isn't even the same diameter.
There is only one MAF worth fitting and it's the OEM Bosch part which usually lasts for many years but often the spurious copy parts never last even a month most times.
