Clicking under shift lever when brake pressed
Old Jan 23, 2016 | 05:58 PM
jamieb's Avatar
Default Clicking under shift lever when brake pressed
Just did the option B for brakes. Coincidentally, now when I tap the brakes, it clicks under the shift console between the front seats under the shift lever. I placed my hand around the plastic housing on the shift console and could feel the tap as I depressed the pedal repeatedly.
Any idea what that is? Only in Park. Solenoid?
Old Jan 23, 2016 | 07:03 PM
mln01's Avatar
That is what it is supposed to do. It's always done it or you would not have been able to shift out of Park. You are just highly sensitive to your truck today. :-)
When you step on the brake pedal the brake light switch not only turns on the brake lights, it triggers solenoid under the shifter that allows you to shift out of park. All good.
Old Jan 23, 2016 | 07:22 PM
jamieb's Avatar
Super highly sensitive. :-).
Thanks!
Old Jan 24, 2016 | 01:22 AM
number9's Avatar
What is "B" option and does it produce a pronounced clicking for the sensitive afterwards? Did a search and found nothing.
Old Jan 24, 2016 | 09:29 AM
jamieb's Avatar
Sorry, option B to fix the 3 amigos in the SLABS module. I unclamped brake lines from the plastic clips and thought maybe one was loose and jiggling
Old Jan 24, 2016 | 12:18 PM
number9's Avatar
Thanks. Will probably meet those guys down the road.
Old Jan 24, 2016 | 05:26 PM
Fallstaff's Avatar
Had the same panic. Its a sound you only notice when you've just changed something and are being hyper-sensitive.
Old Jan 24, 2016 | 09:24 PM
jamieb's Avatar
Yes! The "oh crap! What happened and is it serious???"
rreinholt
Oct 10, 2013 08:47 AM
rezzrover
May 7, 2013 06:02 PM
Externet
Dec 6, 2012 10:17 AM
martinez
Engine & Internal
Jun 3, 2007 04:47 PM
