Clock Backlight not Working?
Old Feb 17, 2014 | 09:23 PM
QuakerJ's Avatar
Default Clock Backlight not Working?
Per the title, my clock backlight is not working and it's driving me nuts at night.
Common problem and / or is the only solution a new clock?
Old Feb 17, 2014 | 09:28 PM
TripleThreat's Avatar
There is a replacement bulb - Tiny little thing... that backlights the clock.
Scratch that earlier thought... You can use a pair of credit cards to remove the clock...
Here's a video...
You can get the replacement bulb from Atlantic British...
http://www.roverparts.com/Parts/YAW000020G.cfm
Old Feb 17, 2014 | 10:23 PM
KernowDiscovery's Avatar
Here's a video...
Clock bulb replacement on Discovery 2 - YouTube
Bulb And Holder Clock (Genuine Part # YAW000020) - Land Rover bulbs from Atlantic British
Wow.. that's it?! Amazing.. I should be happy that it's a simple fix but I had it worked up in my mind that it would be so much harder. thanks.
Old Feb 17, 2014 | 11:16 PM
jfall's Avatar
not easy to get the clock out.
I did it a few months ago.
Credit cards may get it out.
I would use cards you don't care about.
The bulb is a little dash snap in bulb. Orsam
2.5W or so.
Old Feb 17, 2014 | 11:54 PM
2.5W or so.
Cards I don't care about.. hm... expired, maxed, the Queen (& King) of hearts? Oh wait a minute.. I care about those two. Thanks jfall - I'll keep that in mind
Old Feb 18, 2014 | 01:34 AM
Rover_Hokie's Avatar
Credit cards can be a little too thick. Use one of the plastic or plastic coated customer loyalty type cards from your grocery store that are a little thinner than credit cards and smooth, but are thicker and more substantial than a playing card or business card You can buy just the bulb as noted above, or you can buy the bulb in the plastic twist-mount piece that it is set in from AB for a little more $. I also took the ashtray/coin box out to get a little better view and see what is going on on the bottom of the clock when trying push the plastic lock mechanism flat to pull the clock out.
Old Feb 18, 2014 | 04:13 AM
Ok.. this is sounding more and more like the Rover I know and love and less and less like an easy fix. So no Kings and Queens, ok. Loyalty cards. Off in search of loyalty cards... thx Rover
tentoesjoe
Mar 29, 2014 11:38 PM
tango123
Feb 9, 2009 03:27 PM
DDP
Dec 13, 2008 09:32 PM
icancu
Jun 21, 2006 11:00 PM
