Clock Problems
Old Nov 16, 2009 | 05:16 PM
csn4646's Avatar
Default Clock Problems
I have a '97 Disco and the clock doesn't display the right time. It lights up and displays incorrect numbers and random configurations of the seven lines that are used to create each number. If i push on the clock with my finger it will show the time, usually. I was wondering if anyone has had a problem similar to this or have some suggestions on how to correct this problem.
Thanks.
Old Nov 16, 2009 | 05:27 PM
petedisco96's Avatar
My clock is the same. There is a bulb for the light but the clocks go bad. I just use a watch or cell phone.
Old Nov 16, 2009 | 05:29 PM
This is common and you need a new clock, no big deal.
Here is how to replace it.
http://www.roverparts.com/TechTips/C...eplacement.cfm
Here is a brand new one.
http://www.roverparts.com/Parts/STC1800G.cfm
You can get a used one at www.roverlandparts.com or www.autosportsunlimited.com.
Also try www.car-part.com
Old Nov 16, 2009 | 05:45 PM
hilltoppersx's Avatar
the easiest way to get it out i found was with a thicker than normal business card, credit cards are to thick and regular biz cards are too weak and bend at the tabs.
Old Nov 19, 2009 | 03:44 PM
csn4646's Avatar
OK thanks for the help.
Lebowski87
Nov 9, 2005 06:11 PM
AzCamel
Jun 14, 2005 08:39 PM
JA-NH
Jan 22, 2005 02:49 PM
JA-NH
Nov 23, 2004 01:40 AM
JA-NH
Nov 23, 2004 01:38 AM
