Clock removal on Disco2
Old Feb 18, 2012 | 08:56 PM
Street Wolf's Avatar
Put an LED in it and forget about it.
Old Feb 18, 2012 | 08:57 PM
Originally Posted by rimasco
is the bulb for the clock the same as the odometer?? I currently need both..
01 D2 SE
...and no, it isn't. Not even close. Your odometer will need to be replaced. Unless someone has come up with an ingenious solution.
Truth be told, I have an entire gauge cluster you could get and just swap into place. Much easier just to do that.
Old Feb 18, 2012 | 10:05 PM
jafir's Avatar
The bulb for the odometer is replaceable.
Old Feb 19, 2012 | 12:21 AM
rimasco's Avatar
nice!! I guess Ill go with the LED.. so Jafir says the odometer can be done?? why the difference in opinion here??
Old Feb 19, 2012 | 01:03 AM
jafir's Avatar
http://www.roverparts.com/Parts/YAW100020G.cfm
Old Feb 19, 2012 | 04:08 AM
The odometer is an LCD screen.
Old Feb 19, 2012 | 09:13 AM
jafir's Avatar
Yes. A backlit LCD. When the bulb burns out, replace it.
Old Feb 19, 2012 | 10:53 AM
rimasco's Avatar
Thanks for the link Jafir!!
Old Feb 19, 2012 | 06:26 PM
rimasco's Avatar
got 2 replacements from autozone.. replaced both.. credit card (keys) worked great on the clock.. thanks a lot guys
Old Aug 15, 2013 | 02:12 AM
Nain De La Cruz's Avatar
6th Gear
Default Awesome
Originally Posted by Alex J
Thanks for the tips, I got the clock out with two expired membership cards. They worked well because they were thinner than a CC and didn't have raised numbers.
FYI the bulb in the clock is the same one used in a 1993-1998 3 series BMW dash cluster. BMW PN 62 13 1 383 311 $3.06 list price, might be more from a dealer. You can also use a 1.5w bulb, this is what I did because we were out of the 1.2w, BMW PN 62 11 1 391 260, list price is the same as the 1.2w. I keep my dash lights turned down very low so using the brighter bulb is not an issue for me but if you keep them turned all the way up you may want to run the correct 1.2w bulb.
I love this, just order some from ebay, pack of (6) BMW PN [COLOR=Blue]62 13 1 383 311 for just $10 I'm gonna need them for my 97 and 2000 Discos!! Love this forum!
