Clunk in my trunk
Clunk in my trunk
After installing a OME 2inch lift of my 2003 Disco HSE with the RTE SLS spacers in the rear (DiscoMike made me feel better about that decision). I've got OME 751 springs in the front and just those spacers in the rear. I'm also running OME shocks that originally came with a 2inch lift kit from RTE (I think they've switched to all bilsteins now on their lifts... I'm probably wrong about that) lift. I'm unsure of the model/part number on those shocks.
Anyway, my dilemma is this. The front feels great, does a great job. The rear however is CLUNKING when I go over some stuff that causes the back end to drops out. It feels like I have no suspension back there. If I'm going slow over stuff it doesn't seem that bad, but if I hit something with a little speed and the rear extends it feels like the whole axle just drop out to it's full extent and slams against something.
What I've done:
Working with DiscoMike I found out that I didn't have the airbags adjusted properly, the rear was a inch lower then the front. I got that sorted and took her out. Clunk clunk clunk.
After some research I've come up with two theories. 1.) My rear shocks are too short and they are "bottoming out" effectively ripping themselves apart. So I need to replace the rear shocks. 2.) I was looking at the "watts linkage" on RTE's website (http://www.rovertym.com/watts.htm) and wondered if this was my problem.
Anyone have this problem after lifting?
Thanks,
Brian
What I've done:
Thanks,
Brian
I have pictures
Due to the overwhelming response to this post over the past few weeks. I thought I'd add a picture, showing the model number of the shocks I have and maybe someone can suggest a different model with more travel. I've talked to OME and they say, "The ones you have should work". Clearly they are not working (and didn't work on a friend of mine's Disco with a 2 inch lift either) .
This is what is on there.
Thanks, OME and a variaty of resellers have been less then helpful. So I'm hoping someone here has had a similar problem and can help me with it.
Thanks,
Brian
Thanks,
Brian
Thanks guys. Maybe these are/were defective shocks. They did the same thing of the Disco I got them from. He had a full RTE lift though no spacers. We figured it was that. I'm not sure how to check the bushings if you even can. No sway bars etc in the rear. It's all stock except the spacers and the OME shocks.
Mike, thanks. After we "leveled" it I was right at about 36 1/2 - 37 inches front and back.
Mike, which Disco (in the pictures on this site) are you running this setup on?
Thanks again,
Brian
Thanks again,
Brian
