Code 0132 with cylinder 5 misfire
Old Oct 5, 2017 | 07:43 AM
zuke's Avatar
Default Code 0132 with cylinder 5 misfire
I am fairly sure I have a bad O2 sensor or at least a bad connection. It runs in open loop at idle.
I get codes 0305 and P0132 (O2 sensor circuit high voltage (bank 1, sensor 1) Front sensor LH bank short circuit to battery supply)
Does this seem right and do I need to replace O2 sensors in pairs?
Old Oct 5, 2017 | 08:10 AM
LR03NJ's Avatar
you dot have to change both. If you prefer changing both, that should be fine as well. Fix the problem side first, if you mess up with the other side, youll be fixing more stuff.
scarrell
Nov 16, 2012 06:04 PM
FLDISCO
Nov 18, 2011 07:53 AM
Bryan H
Sep 1, 2011 12:48 PM
rover
Freelander
Apr 28, 2008 08:42 PM
lajilana
Sep 2, 2006 10:47 AM
