Code 307
Switched plug #7 and #2 (easy to get to) to see if error moved with the spark plug. Also inspected the plug wire at the plug end and did not see anything unusual. Still getting the misfire code on cylinder 7.
The only other things I can think of is the coil or the electronics that send a signal to tell the coil to fire. Any other ideas?
