Code 413 - Secondary Air Valve... Mysterious Unconnected Hose...
it doesn't look like you have SAI heads installed. maybe i just can't see it in the photo, but i'm not seeing the vacuum pump or the hoses that come off the head. if you don't have SAI heads installed and you have a SAI ECU you will always get the SAI codes unless you have the ECU reflashed to a non-SAI format.
I've cleared the following codes in the 3 weeks I've owned this thing.. Bought it for $1500 due to the guy leaving town the next day... Spent $80 in parts so far..
Brake Light
Three Amigos (reset with Code reader... hasn't come back)
1590
1884
112
308
305
300
Replaced ignition wires and plugs.
Replaced the MAF from my parts Rover
Cleaned out Throttle Body
Replaced Air Filter
Unplugged and Plugged in the Brake Fluid Tank Cap
Brake Light
1590
1884
112
308
305
300
Replaced Air Filter
Rorybuckminster (11-05-2019)
I’m currently in the same boat my heads have had to be replace with a non SAI heads but my ecu is still kicking p0413.why would someone do this ?? What do I do get a non SAI ecu and reprogram?
If you have SAI heads, they will have 2 threaded holes between the spark plugs on each.
They should have brass tubes coming out to hook up to the rest of the SAI system.
Those holes can be filled with threaded plugs. And I've seen hack jobs of the tube ends from the heads crimped closed.
If the heads are non SAI in an SAI truck, then someone swapped the heads, or the whole engine, as they are notorious for overheating and blowing head gaskets.
I also have a good set of SAI heads from a running 4.6 if anyone needs a set.
Sixpack577 (11-05-2019)
