Code EXPLOSION!
Code EXPLOSION!
I just had my land spit out 10 codes... Holy ****! These are the codes that it has brought up:
1884
0332----knock sensor
0340---crank position sensor (I just replaced this)
0445---Purge Valve
0448---evap something?
0102---MAF (I just replaced this)
0135--O2 sensor
0155--O2 sensor
0141--O2 sensor
0161--O2 sensor
Can you guys help? I have read about a lot of these codes and I am a little overwelmed at the sheer amount. Where do I start? I just ordered 4 new O2 sensors, a purge valve, and another crank position sensor.
Thanks for the help
1884
0445---Purge Valve
0135--O2 sensor
0155--O2 sensor
0141--O2 sensor
0161--O2 sensor
Thanks for the help
Well, my rover is running pretty rough, kind of a low idle almost to the point that it wants to die. I have had a couple of rough starts since i got all the codes. It happened earlier today while I was driving...the car was running great until that point. Really smells like exhaust fumes under the hood.
As far as looking up the definitions to each code... I have, and I thought that was what I wrote out to the side of them. Obviously they are not complete but I figured everyone would get the point.
If anyone has any ideas what could be causing this i'm all ears/eyes, I'm not a mechanic so my solution is just replace everything the code reader says is bad and go from there.
Cancel that order now! For starters p0340 is CAM position sensor...not crank...i've had all these codes appear at the same time as well. Check fuse #2 in your fuse box (the under hood one not the interior one). I bet you its blown. This fuse covers CAM position sensor, evap purge valve, all 4 o2 sensor heaters, and your MAF. if it blows they ALL throw codes hence your dilema. If you replace it and nothing happens yuo get lucky, else you have to trace each individual component to find out where the short is that is causing the fuse to blow. This is usually a bare wire shorting to the block/bay though in my case my cam position sensor went bad and was causing it to short. Good luck hope you get lucky and had a fluke fuse blow!
When I bought my truck and had the same issues I was about to do the same thing you did and replace the same parts. I decided to take it to a dealer to have it looked at and got a nice tech that called me after I left recommending I check the same fuse. Sure enough there it was, $100 spent at the dealer saved me $hundreds in parts.
