Did you replac with aftermarket cats? Those are known to fail pretty quickly compared to the OEM ones sadly. Another thing to check is to make sure your rear O2s are functioning properly. Those are the ones that tell the ECM if a cat has depleted outside of spec or not.
Not on my Rover, but my '06 Accord has thrown the P0420 few times. I've cleared it each time, and it returns only after many, many months. I'd try that first and see if it comes back, and how quickly. As you likely know, the post-cat sensors have nothing to do with engine management so you can also just ignore it unless a state emissions inspection would compel you to replace the cat again.
Just like the pre-cat sensors, one way to test whether the code indicates a real problem with the cat vs. a faulty sensor is to swap the sensors side-to-side and see if the fault follows the sensor to the other side.
It could also be your truck is just saying it needs some weed (420, get it?).
