is code P1590 part of the three amigos?
Old May 17, 2009 | 03:08 AM
VikingDiesel's Avatar
Default is code P1590 part of the three amigos?
I have the three amigos on, disco mike says since my brakes are squeeling, its most likely the speed sensors which means I need new brakes. I checked the codes and p1590 was the only code that popped up and I was searching around the forum and it seems like that code is fauly speed sensor..., is that true? also not sure if this makes a difference but as soon as I start my car the ABS light comes on instantly and after a few seconds the TC and HILL DECENT control then pop up, not sure if that means anything.
Old May 17, 2009 | 08:34 AM
The 1590 is a Rough Road/ABS fault code which will always come on when your 3 Amigos are on, it does not mean anything else, so go get your brake squeak issue resolved and then find someone to read and clear your ABS faults.
sayeedA
Nov 15, 2011 11:02 PM
agthird
Jan 18, 2011 02:09 PM
larson3000
Jul 30, 2010 11:26 AM
silver06hemic
Jan 2, 2009 03:51 PM
