codes????
Old Feb 9, 2010 | 10:43 AM
chad420's Avatar
Default codes????
went and got my codes read today. Getting PO171, PO174, PO734, and PO733???? Any help would be appreciated....Thanks
Old Feb 9, 2010 | 11:04 AM
okdiscoguy's Avatar
You have a bad MAF. What kind of air filter are you running?
Old Feb 9, 2010 | 11:07 AM
chad420's Avatar
i beleive just a fram from murrays
Old Feb 9, 2010 | 11:10 AM
chad420's Avatar
I've also been getting the three amigos codes in the dash interrmitingly. I will be doing a full brake fluid change next week. How come those codes didn't show up on the scan. I went and got them read with the three amigos lit up on the dash???
Old Feb 9, 2010 | 11:13 AM
lipadj46's Avatar
You have to read them with a land rover specific ABS scanner. The only amigos specific ODBII code will be 1590.
Intermittant amigos generally means you need to the modulator fix.
Old Feb 9, 2010 | 11:23 AM
okdiscoguy's Avatar
Are your brakes squeaking?
Old Feb 9, 2010 | 12:20 PM
chad420's Avatar
no brake squeeking....
Old Feb 9, 2010 | 11:00 PM
chad420's Avatar
so i take it that all my codes are maf sensor related??? and what type of air filter should i be running in my DII
Old Feb 10, 2010 | 06:02 AM
hilltoppersx's Avatar
paper type. not K&N
Old Feb 10, 2010 | 08:14 AM
okdiscoguy's Avatar
The lean codes plus the 4th gear code point to your MAF.
