Codes from Nanocom
I swapped the BCU and ECU...bought a nanocom .. today I got these codes and msgs ...
1) P0705 position switch monitoring error... Gear switch Z closed.... Code 0654
2) Code 008 - Drivers airbag measures open circuit intermittent
3) Error - Hella CC unable to start communications with ECU
4) Transport mode disabled
5) 02-02 signal failure from engine ecu 002 times
Code 0654 popped up after battery drain and dealer visit .. it wasn't there before ..
Nanocom Hella CC info
4) Transport mode should be set to disabled.
“Transport mode: This is a lock mode for transportation of a vehicle or for work to be carried out.”
Nanocom Wabco SLABS info
3) I’ve always has trouble connecting to my Hella cruise control ECU and notified BlackBox about it on their forum.
Aight. Thanks man . ..I was thinking it meant that I couldn't transport something ..
Now I just gotta find out this 0654 code.. Is one of the XYZ switch supposed to be closed?
Ild turn off the alarm system....you might run into problems with it. After its off reprogram your fobs to the bcm if you plan to keep those units in. If they work then you should be able to turn the alarm system back on. Personally I left mine off,
statichead2k
Oct 15, 2017 08:56 AM
andytaylors
May 27, 2010 11:59 PM
