Coil ADVENTURE TIME!!! W/pics!
Old Aug 12, 2016 | 08:31 PM
shanechevelle's Avatar
Goto harbor freight, for something like 5.99 they sell a little plug for spark plug wires that tells you if they are bad.
I had this very same problem few months ago, the thread is here, and the fuel injectors fixed it.
Remember, our Rover doesn't have a fuel filter.
Old Aug 13, 2016 | 08:56 AM
The_OGCJR's Avatar
Thank you guys!
Disco oh no: I don't have a test light but I'll get one today
Army rover: I did break the valve cover breather plug on the intake, and I was going to fix that after I figure out the misfires. I've been holding it up to the intake to see if it smooths out the idle and it does not.
So today I'm going to rent a compression checker, and go to harbor freight for that tool.
After I check compression I'm going to take the manifold back off and check the power at the harness plugs into the coil. I read someone had a similar issue because they had a bad ignition switch and the computer would cut power to the coils long enough to create a misfire...I do have ignition switch issues.
Anyone have a good way to check the injectors?
Old Aug 13, 2016 | 04:41 PM
The_OGCJR's Avatar
No compression cyl 5 even after I put oil in it.
done with a cold engine. 3-5 compression strokes each time
Do I have to do it with the engine warm because damn, I'll burn the hell out of my hands. Also I don't remember if I held the throttle open.
cyl 2 = 145
cyl4 =110
cyl 6 = 125
cyl 8 = 120
cyl 1 = 115
cyl 3 = 120
cyl 5 = 0
cyl 7 = 120
Old Aug 13, 2016 | 04:42 PM
The_OGCJR's Avatar
opinions?
Old Aug 13, 2016 | 06:32 PM
disc oh no's Avatar
If you don't have any compression at all on cylinder five, even after adding oil, it could have a valve stuck open. Or a hole in the piston or broken rings.
Old Aug 13, 2016 | 07:40 PM
The_OGCJR's Avatar
I think stuck valve cause I've got loud top end noises. I've got a LR tech coming over next Saturday to do a leak down test
Old Aug 27, 2016 | 06:38 PM
The_OGCJR's Avatar
well the exhaust valve on cyl 5 is stuck in the down position. So now I'm taking the heads off. I got it to the point to where I'm doing the head bolts, and yep...pain in the *** 1st one is stuck...I have a 2 foot Matco breaker that hasn't worked so I'm off to Home Depot for some pipe and I'm gonna make it in to a 4 foot breaker. And buy an impact socket as my sockets are craftsman, but my wrenches are Matco
Old Sep 1, 2016 | 08:09 PM
The_OGCJR's Avatar
So the valve spring broke! What would cause that?!
Old Sep 3, 2016 | 11:52 AM
The_OGCJR's Avatar
Update! The heads are off. 218k and no coolant leaks! <br/>Crosshatch is on the liners, all Pistons make full sweep, no edge on the liners. So now the heads are otw to the machine shop
Old Sep 5, 2016 | 03:18 PM
The HUESTER's Avatar
hey i just posted a video of how to get to the coil pack out on my disco2 while i was changing the spark plug wires. It maybe of some help to you guys check it out.
