Coil pack mounting question
What is proper way to install the coil pack? I assume you put the lower intake on and then plug the wires in prepping the pack and mount to lower intake. Next you would install the upper plenum? However I have had a tough time getting the upper plenum to slider under the coil pack bracket. It won't sandwich.
Here is what I am talking about
Is there something I am missing like some spacers that go on the lower manifold? Of course I have SAI and I assume that bracket mounts on the top plennum and top of coil bracket?
