Coil pack mounting question
Old Jul 23, 2012 | 10:05 PM
jpmiller's Avatar
Default Coil pack mounting question
What is proper way to install the coil pack? I assume you put the lower intake on and then plug the wires in prepping the pack and mount to lower intake. Next you would install the upper plenum? However I have had a tough time getting the upper plenum to slider under the coil pack bracket. It won't sandwich.
Here is what I am talking about
Is there something I am missing like some spacers that go on the lower manifold? Of course I have SAI and I assume that bracket mounts on the top plennum and top of coil bracket?
Old Jul 23, 2012 | 10:09 PM
DiscoRover007's Avatar
You can also mount it to the top of the upper intake instead of the lower intake. I too know your problem very well and I think you just might have to choose which one you want to bolt it too.
Old Jul 24, 2012 | 07:02 AM
drowssap's Avatar
if I remember correcty you put the upper and lower on then slide the coilpak back into place. It is tricky to get the bolts to line up but a cool head and time is all that take.
mln01
Jan 3, 2016 08:07 PM
pinkytoe69
Apr 18, 2013 01:00 PM
zukilj20
Jul 20, 2012 05:20 PM
best4x4byfar
Jul 3, 2012 07:59 PM
GoldDiscoII
Dec 3, 2006 12:06 PM
