Coil Pack wiring diagram
Old Apr 23, 2008 | 08:44 AM
JEFIII's Avatar
Default Coil Pack wiring diagram
Hi All. I am going to attempt to install new Magnecor 8mm's on my '04 Disco this evening. After reading through everything written about doing the job, Irealize I need some kind of wiring diagram for the coil packs. Anyone have this information?
Thanks, JF
Old Apr 23, 2008 | 08:52 AM
tee51397's Avatar
Default RE: Coil Pack wiring diagram
I'm sure someone can give you the actual diagram but when I did mine I numbered the old wires and the coil with a paint marker as I removed them then compared the new wires to the old so I knew which was which and where on the coil they went. Worked out really well for me.
Old Apr 23, 2008 | 09:12 AM
jspbtown's Avatar
I did mine recently (on my 2004) and messed them up and someone posted a diagram for me.
https://landroverforums.com/m_47883/tm.htm
Old Apr 23, 2008 | 09:57 AM
Here you go, hope this helps.
DISCO II COIL LAYOUT
TOP
PASS. SIDE DRIVER SIDE
8 5 6 1
2 3 4 7
BOTTOM
Old Apr 23, 2008 | 11:10 AM
JEFIII's Avatar
Thanks, guys. Just what I needed. I'll let all know how the job goes. JF
bamarover
Feb 6, 2008 01:48 PM
jleblanc
Dec 8, 2007 07:56 PM
crownaviation
Sep 14, 2007 09:41 AM
hendoc3
Jul 19, 2007 06:02 PM
GoldDiscoII
Dec 3, 2006 12:06 PM
