Coil spring conversion
Old Feb 19, 2011 | 02:01 PM
rphotographer's Avatar
Default Coil spring conversion
I just finished my coil spring conversion and new shocks!!!
I will not have to worry about the air suspension anymore.
I should have done this a long time ago !!
Ralph
www.ralphduke.com
Old Feb 19, 2011 | 02:18 PM
DiscoIIBrandon's Avatar
Nice! Did you have to use a tap for the bolt holes for the spring seats?
Old Feb 19, 2011 | 03:18 PM
No the holes are already there.
Old Feb 19, 2011 | 04:20 PM
Agreed. Was just wondering why the write up in the how-to section used a tap and if it was necessary. I assume he just used some bigger bolts or the threads were stripped?
Old Feb 19, 2011 | 07:26 PM
EVN137's Avatar
The hole is there but not tapped. Use a 10mm x 1.5 tap. Then you bolt down the
spring seat.
Did my conversion the other day.
Old Feb 19, 2011 | 07:54 PM
coleman1's Avatar
Did my 97 p38 a few years ago, really takes a load off not having to worry about that bad air system having your truck look like a low rider when you come out one day to go to work............haha
Old Feb 20, 2011 | 03:03 PM
Default coils springs
yes the holes are there and we had to tap them out to 10mm.
took about 15 mins
I also put on new shocks as well
the whole operation took about 2 hours, and we had never done anything like this before.
my friend had the jacks, jack stand, and the tools.
Ralph
www.ralphduke.com
Old Apr 25, 2011 | 07:07 PM
Landy Idaho's Avatar
What did you do about the compressor? Did you have to disarm it or something so that it would quit operating?
Old Apr 25, 2011 | 07:23 PM
kcabpilot's Avatar
How often do air springs go bad? I'm asking because I really don’t see a lot of threads on the subject. So why do people spend so much time "worrying" about them?
I could see maybe doing this if there were a problem and either a spring or compressor needed replacement but why replace a perfectly functioning system? Unless I'm missing something.
Old Apr 26, 2011 | 01:18 AM
kcabpilot, my problem is that my rear airbags keep deflating and because they are so expensive I want to switch over to the hassle free coil spring suspension. The only thing stopping me from doing it right now is that I am not sure on how to handle the compressor once I have converted to spring.
