Coil Spring Conversion
I replaced the leaking air springs a year ago with Arnott air springs. Both sides have small pin holes leaks. Arnott said I had to send them back to cover under warranty. Can't be down with the vehicle that long. Also have replaced the compressor. Tired of messing with the air suspension.
Why do you have to replace the shocks at the same time?
why not call Arnortt order new springs, when they arrive, ship Arnott the old spring and when they warrenty them just have then credit your account. that way you are not down any time and only have to carry the cost of the new springs on a credit card for a week to 10-days. If you remove the SLS you will most likely talk yourself into going with a at least 2 inch lift, which meens new springs, shocks, brakelines, ABS cable extension.
