Coil Spring Conversion
I called Arnott and they siad it is probably just one defective air shock dragging the other one down. They are going to send me on new air shock and I will try that. Thanks for the advice.
03 Disco II SE
05 LR3 SE
08 RR Sport Supercharged
03 Disco II SE
05 LR3 SE
ATL BRIT has a kit for $1000 that supposedly replaces everything you need to replace. Any comments on that kit?
Seems that you get the Air Suspension Fault code cleared Before you do the conversion, and the message stays off the dashboard then.
Big Jim, what's SLS? Also, the wheel arches on your signature pic's truck are like those on my LR3; they seem to be about an inch higher than the tires while the fronts are about 3".
Are you getting any lights on the dash? Was that taken in OEM form, or after conversion to shocks?
You also need the dealer to cancel the SLS in the computer, otherwise it will beep like crazy.
The peace of mind alone is worth ten times the price of the spring conversion. Had ACE and converted to an Old Man Emu lift with coils all around with no problem at all.
b_woodroaster
Nov 5, 2010 08:54 AM
southfloridadiscoII
Jun 18, 2009 08:48 AM
lonely king
Aug 5, 2008 02:26 AM
